Axle Nut size for 2001 YZ 125?
lakersfan77
In First Gear
In First Gear
Postby lakersfan77 » Fri Apr 11, 2008 10:34 am
Anyone know the axle nut size for a 2001 YZ 125? I need to tighten the chain. I know my buddy's CR125 is 32mm... any thoughts? Tried to google it with no luck.
Danno
Axle Nuts
Postby Danno » Fri Apr 11, 2008 10:59 am
I just measured my WR 426 axle nut and it's 26 - 27 mm. A SAE 1 1/16" fits just fine. From 19 mm and up, SAE wrench sizes will work with out any problem. I like to use six point, thick walled impact sockets for any fasteners that are torqued tight. Hope that helps! Danno
"Keep the rubber side down, unless a fashionable loop-out is plan B!"
corbingravely
Re: Axle Nut size for 2001 YZ 125?
Postby corbingravely » Mon Dec 09, 2013 3:15 am
It is a 27 mm sized blot. If you do not choose the correct size and I mean if you even step it down a little bit everything is going to collapse. So choose it wisely. I hope this helps.
CORBIN GRAVELY
omnitech support
corbingravely
Postby corbingravely » Fri Sep 15, 2017 7:37 am
I believe its a 27 mm which is the same size as the front sprocket nut
EHR software
