2016 KTM 250xcfw, cold start problem
Technical articles, tips, tricks and advice from the experts (and there are plenty of you!) on jetting, suspension, riding techniques, muffler bearings, powerband installation or anything dirt.
Moderators: OMRA, dlharte, oregonsage, Tawmass
User avatar
chainsaw
Pee-Wee Class
Pee-Wee Class
Postby chainsaw » Mon Nov 06, 2017 6:26 pm
EFI has stopped feeding rich fuel mixture on cold startup. Starts easy when warm and runs perfect, makes full power. Bike just suddenly hard to cold start, Have to roll throttle up and down and maintain high idle or it will die. Over 100 hrs on bike, valves are on spec.
KTM 250xcf w
collarbone
Beginner Class
Beginner Class
Re: 2016 KTM 250xcfw, cold start problem
Postby collarbone » Sat Nov 11, 2017 8:59 am
Check the sparkplug gap, or better yet swap it with a new one. Then verify the TPS voltage has not drifted, which could also be adjusted slightly to improve this. Compression/Bleed-down test would also be on my list to verify. If you have a riding buddy with a matching ECU, swap and see if the issue is with the box.
Return to “Technical”
Users browsing this forum: Bing [Bot] and 1 guest
